Has anyone tried to setup a gauge cluster/monitor using obd2 port???
Looked at a few different products haven't really found exactly what I am looking for, I would like to find a obd2 plug in that would feed a lcd screen or small tablet and give different gauge options so I could use that as my gauge cluster. Just figured it would make wiring cleaner and use the factory sensors the motor would be ls swap and I figured I would save the obd2 plug anyways. The only thing I have found that is close is the CTS insight and the only problem I have with it is it really isn't made for outdoor use the only gauges I really would care to use would be rpm,oil pressure, water temp and voltage
