mark
No that I've had my "new" truck for a month or so, time for me to do some preventative maintenance.
What are some recommendations on fluid and filter choices, where to get them and what should I be looking at price wise?
Delo 400 would be my first thought on motor oil, as I can get it pretty cheap and easy at Costco. But I did notice Shell/Rotella at Shuckes this morning and it wasn't priced bad. Also planning a little 2-stroke oil
(in the fuel)
A full batch of synthetics would be nice, but I don't know if I'm ready for that $tep just yet. But if its the right move...
What are folks thoughts and recommendations about oil testing? Little web searching strikes me as the most logical idea to get best bang and $ out of oil changes, especially if your running $yntetic.
And don't say look at Diesel Place. I have a window open there right now and am playing the search game in between work projects, but there is Information and Opinion overload there, taking a little while to filter it all out.
Truck is a '04 LLY, it will probably be getting 15K or so a year. Mostly city/short drives, empty to mid loads with the occasional full bed of heavy trailer.
- Motor Oil and Filter Change. - sounds like about 11 qts
- Looks like I should atleast change the tranny spin-on filter, if not do a quick fluid drain and fill. Ideally I'd drop the pan and change that filter too, but thats more work than I have time for right now. - sounds like about 2.5 gallons with just a drain and fill, 4+ with a flush.
- I'd like to change the fuel filter as well, as I have no idea when that was last done and is seems like my millage has been getting a little worse each tank.
- Probably should drain and fill the t-case, especially since its the same fluid as the tranny.
- For right now I'm just thinking check the fluid in the diffs, I'd like to change it another day.
