X2 here.looks a bit deep, I'd pull a couple thousandths from the pinion. See how your drive side mark is a straight line all the way across the bottom of the tooth? I like to see a bit of relief in it.
That will probably open your backlash up into spec too, without messing with the carrier
plus you'd be surprised how long a "bad" setup will run...
