Overcharging Toyota
NotMatt
Wenatchee
Anybody have any thoughts... what else other than a bad voltage regulator can cause an overcharge situation on a '93 Toyota truck, 22re? My brother picked up a new project and I'm trying to nail down this one major issue... The volt gauge is pegged all the way right at anything over idle, and the charge park lights come on when the RPM's are anywhere above idle. The PO put a new alternator on recently, and also just recently put a brand new battery in (sticker says 1/08). He also re-did the battery cables, I'm assuming to try to troubleshoot this same problem. Unfortunately, I think the overcharging alternator has killed the battery.
I have not taken the alternator out to have it tested. That will be the next step tomorrow night.
I have checked/fixed/cleaned every ground. The battery to block ground was the only one that was good. The battery to body ground was a piece of speaker wire from the negative terminal to one of the bolts that holds the plastic fuse box to the fender, the ground that comes out of the alternator harness was hanging loose not connected to anything, and the head to body ground was three pieces of corroded wire makeshift repaired with the "twist and cover in electrical tape" method. :rolleyes:
Any other possibilities before I take the alt. out tomorrow night? This is a 93, so it's internally regulated. I checked the plug on the alternator itself and all is good and clean there. Could the condition of the grounds previously be a possible cause of damage to the internal regulator on the alt, causing it to basically burn out and overcharge, even though I've fixed all the grounds?
I guess it's possible that it was a dud from the start... it is an "autozone special" replacement alt.
yeah, sounds like you're pulling it-those bad grounds could definitely have damaged the alt.....maybe have him pony up and buy one of better quality?
Its a vato zone part... That says it all right there. Id check the battery with a multimeter to be sure its putting out more that 14.4 (ish) volts. Anything over 15 will freak things out as you describe.
Yep, the PO couldn't find the receipt for the alternator he put in, so we'll be buying a good quality one this time and skipping the "lifetime warranty" junk ones that seem to be bad out of the box about half the time.
Yeah, about 16 volts at idle and it jumps up from there quick when you rev the motor.
Theres really not much else that could cause high voltage other than voltage regulator/alternator problem; I'm thinking a short in the battery or running the truck with no battery could be making the alternator act funny...Humm...
Put a known good battery in it and see what it does; your not gonna hurt the battery if you dont let it get too hot. If the loaner battery gets too warm stop and pull it back out. If the alternator begins to act normally; (about 12.5-13.5 volts after running a couple of minutes), then battery is the problem.
Most parts houses can spin your alternator and check it too.
Another reason I always have them put a alt or starter on the tester before I walk out the door with it! Nothing pisses me off more than doing something twice because of a defective product.
When I put my motor in, I made sure I had all new grounds and good clean surfaces for them to ground too! I made some out of some Monster Speaker wire. Works real good! :awesomework:
