the nut with a lock washer keeps coming loose. that last time i took the pitman arm off cleaned both the pitman arm and the threads of the steer box and used lock tight and it still loosing up.
this is on a 99 jeep wrangler stock pitman arm and currie steering system. i had a drop pitman arm but put stock one on after installing currie steering system.
do you have to use red lock tight on the nut.
thank you judd
thank you judd
