Powersteering pump issue???
nealcj8
Florence Al.
I was just wanted to know what pump everybody is running? I currently have a PSC but I think it is shot. I am running a double ended ram and a LS motor.
I have a PSC P pump on mine, it is also shot.....BUT, after talking with Lance at PSC, it was more than likely my own fault. If your lines are not routed correctly or if you have a restriction somewhere in your system, it will kill a pump in a hurry. I am going to send it back to them and have them rebuild it and probably add a -12 feed to the can. Also, it was recommended to run a -8 return line.
How is your setup ran?
Brian
i run a stock gm pump that has been the pressure fitting drilled out a bit, and run a single ram , full hydro, works good, also need to put good fluid in there and a cooler, heat is what kills them,
seems like PSC has a lot of problems with there pumps, not saying they do,, just seems like it
