Pressure gauge issue
Fattz
Mt. Vernon
is there any one in the business of fixing pressure gauges? i bought a small liquid filled gauge and pressure pegged the gauge now it wont zero out. it is stuck on 24 psi. i didn't want to buy another if i could get this one fixed. not sure if it's possible i hate to waist it.
thanks Fattz
A calibration place is your best source for that. if the gauge is worthy of calibration. most cheap gauges are not calibrateable...cheap being under $300 or so.
if the gauge still tracks up and down you can probably just take the face off and rezero the needle on the stem.:awesomework:
you mentioned liquid filled so you might be ok with a cal lab.
there used to be a Northwest Calibration in Everett, Seattle and Bellingham i believe.
It would prob cost more to recalibrate than fix. What is the gauge used for?
What PSI range?
My work has some gauges depending on the application, located in Kent.
it's a cheap 100 psi gauge from Jegs. i am or was using it to monitor fuel pressure on the diesel a the pump. i don't think it will be worth calibrating. i will try to open it up and if it doesn't work i will buy another.
thanks though.
