Project White Truck (turbo ranger) 2wd build
FastEddy
Carnation
So My buddys first ride was a 1986 ford ranger std cab long bed white 2 wd with a 2.3 , with some mold and rust:awesomework:. Its been a grat little hoopty ride for the past 5 years. he sold the truck to another freind about 2 years ago, who spent an outrageous amount of money buying everything to turbo the truck, (with no performance internal parts). he drove the truck turboed stock for like a week it stopped running and he assumed the motor was blown and didnt care. sold it back with all the turbo stuff on the motor back to the original owner so he bulit a turbo motor (specs will be below). then he threw it in his wheelin ranger has a 4 in lift and some 33s nothin special. well that truck is getting built into a wheeler with a efi 302 and a 9 in and hp44. the little motor wouldnt handle it, and it blew the fel pro head gasket we put on after the first copper one didnt seal right. so now that motor is out of the 4x4 ranger and going into a 1987 long bed 2wd white as well that he got for 100 bucks missing the engine and with a little bit of front frame damage that is geting fixed and did not affect how the truck drove. so heres the specs and what all is gettin done to the truck and what it came with. all the work is getting done at my shop with my help so i figure why not have build thread.
Engine: Ford 2.3
-Mr gasket copper head gasket (using dowel pins and copper sealer this time:awesomework:)
-crower forged rods longer than stock
-Racer walsh lightened crank
-Shorter forged 8:1 wiesco pistons
-bored 40 over
-Comp Cam dont know the specs
-arp head studs
-xs power wastegate
-xs power turbo header
-54lb an hour injectors
-255 walboro fuel pump
-Bigger fuel rail and a mechanical fuel pressure regulator
-bbk throttle body its huge dont know how big it is had to build a spacer between the upper and lower intake manifolds to clear the valve cover
-intake manifolds, and throttle body, port and gasket matched
-ported and polished head
-svo mustang computer and stand alone harness bought new
-full gauges
-bigger oil pump
-A/R (airresearch) garrett off brand T3/T4
-Front mount intercooler
-Oil cooler with oil filter relocation kit the lines are huge the system holds 7 quarts
future plans are a 16 valve dual valve spring volvo 2.3 head
Tranny:
-Stock 5 spd
future plans are a t5 tranny
Rear End:
-Welded 7.5 with 3.73s i
-Future plans when this blows up are a disc brake 8.8 out of a limited explorer
-Springs mounted under axle
Front End:
-chopped springs. will soon be new i beams that lower it 3 inches with stock springs back in this will correct the bad camber
using the curent driving truck as donor truck for the front part of the frame and the tranny
now for some pics
First pic is of the beat up ranger
The current work being done is the motor is geting re head gasketed this weekend
the core support removed it was bent and didnt have the custom cuts needed to fit the oil cooler and inter cooler
battery relocated to the bed
frame will be fixed once motor is re assembled ready to be installed
Drums painted blue haha
anything turboed is cool ive had a few turboed cars and was gonna turbo my 2wd bagged toyota but traded all my turbo stuf for a dana 60 and 14 bolt, but atleast i can watch your build it looks like its gonna be a beast:awesomework:
sweet :awesomework: I've always had a slight desire to do this same swap. I cant imagine it being anything but fun to drive.
There's a guy with a turbo lowered 2wd 4 runner that lives by me. Pretty sick little rig.
cool build. now lift it and get some deaver springs out back and jump it at the dunes and around here. they make great prerunners. Motor looks just like my old merkur xr4ti motor. fun lil cars. I was thinking of building a 2.3 turbo and toss it in a '67 122 series volvo or a '70 142 series with a t-5 and just have fun with it. im following this one, cool man.:awesomework:
Where would one get some deaver springs???:;
so i got some bad news we pulled the head off last night the motor and head are both ****ed number 4 piston leaned out after an injector failed which cracked the head melted some holes in the piston and scarred the cyl wall badly so a new block and pistons get ordered sometime this week or maybe need a 2.5 block and crank make a stroker motor heres some pics of the carnage:puke:
when the motor was in a 4x4 it was a blast to drive would start boosting and burning out in 2nd gear dry pavement cant wait to drive the 2wd its probably going to be in the high 12s low 13s on the quarter is my bet anyone know of the closest dyno shop around
New Motor located this morning! its out of a 1986 turbo coupe with 76000 miles pictures will be posted later tonight or tommorow after we go pick it up
yea merkurs are bad ass no this truck stays slammed you have no idea how much fun 4 studded tires and a turbo are on snowy roads
GET ER SIDEWAYS :011::011::011:
Engine aquired even came with a water cooled oil cooler and water cooled turbo i think its stock but who cares! took me a day to find a screamin deal on a new motor 300 bucks fawk yea:cheer:
3.0s bring the suck and he already built and still has a bronc deuce with a 4.0 in it ill post some pics that was a pretty easy swap. and the price has been right on everything we have picked up. we were talking and im gonna build a long bed 2wd ranger with a 4.0 in it no v8s there to heavy you loose control
