Well I have got a little work done on this thing so I figured it was time for some NWW criticism. The truck is a 1949 Willy's pickup. It has a really straight cab and front end, the only rust I have found is in the floor pans. The bed is kinda rough but usable. My plans are to leave the body as you see it. It will most likely end up with a Chevy 5.3, nv4500, 32 spline np205 and half ton axles. I am leaning towards a Scout 2 Dana 44 front (similar width) and a 44 or 9' Ford for the rear. My plans for the truck are to build a reliable street rig and maybe snow rig. This thing won't be seeing much for trails if at all.
I bought the truck as you see it. No running gear at all. Since getting the truck, the cab and bed have been pulled off the frame and the frame was sand blasted. The frame is in great shape other than the two rear most crossmembers were bent. I removed them and replaced them with 3 1/2" square tube. I also picked up some steel plate and have began boxing the frame front to rear.
And that's where I am right now. All the plates for the frame are cut and fit and the inside of the frame has been shot with weld through primer. I still have a few more plates to tack on before I begin finish welding.
