TBItoy
I've read a bunch of discussion about propane engines, cams, etc in some of the other threads about efi vs. propane.
Has anyone did a build, or compiled the info about building engines for propane?
Here are some things I've picked up: (feel free to add or correct me)
- propane is higher octane and can handle higher compression to pick up some lost power from the energy per volume of 'pane.
? How much compression is too much? from a starting/reliablity
- decent vacuum at idle (less duration/overlap) helps with starting/idling (starting without having to prime the evap)
? Do most people just pick a cam from the catalog, or the cam manufacturers have "propane" specific type cams?
-a single mixer/evap setup will only support <400 (maybe 350?) hp.
? what is the commonly accepted HP limit of a single system? rpm per cubic inch limit?
- I assume you can run a single mixer on a larger cubic inch motor if you don't intend to spin it fast, or vice versa (small engine/high rpm)
I'm considering building a 351w for propane. I figure with the limitations of a single mixer system, there is no sense in building a stroker.
