Yes. Propane burns slower than gas, therefor you must initiate the ignition cycle before you would with gas so that the cylinder reaches peak pressure at the correct time / relatively same time as gas would. If you start it too late the piston will be running away from the flame and result in poor torque / performance / low cylinder pressure.
