propane
  • Thread starter Thread starter BIG HOSS
  • Start date Start date
    Votes: 0 0.0%
    Votes: 0 0.0%
  • Total voters
B
BIG HOSS
Guest
ok guys i got a question bout some propane. me and my dad just put his on it yesterday. and its runnin good. but my question is. is there some fine tunein that i need to do to it. like timin? its pops a little when u throttle it. what does it need to be set at. and what kind of spark plugs do yall run. and one more thing the break vaccum booster line that went to that back of the carb where do u run it for the breaks?
i just did a search on here and pirate and yahoo and got enough info to tune on mine, uses little much propane but runs like raped date! sounds like urs is lean, mayb sum these tech guys speak up and help
Depending on which one you have there will be a lean/rich screw in the back of it some have a 3/8 bolt with a spring some take a 1/8 inch Allen wrench just play with it till you get it where you want it. Timing should be run at whatever you normally run and I run the autolite race plugs in mine there kinda pricey but do the trick for me. You can get a Holley base plate that has the vacuum port on it or drill your intake and put a fitting on it I have done that on previous motors and it worked well.
call this guy he set mine up Search ResultsPrecision Sales and Service, Inc.;Birmingham, AlabamaPrecision Sales and Service, Inc. 451 64th. Place South Birmingham, Ala. 35212 ... service for all your alternative fuel needs as well as complete fleet and ...
