85toyo
I posted about this in another thread but never got a response. When I first did all of my links, I screwed up and made my lowers to small and thin. They are 1.75x.250 wall with 7/8x3/4 Heims. To top it off, the bungs are already welded in.
Here are my options to fix it without spending **** loads of money on all new tube and bungs.
1) Grind the weld down on one side and insert some 1.25 tube in the .120 or .250 wall flavor then reweld the bung.
2) Grind the weld down enough to slide 2x.120 wall tube over the 1.75. Add a few rossette welds down the side then weld the outer tube to the bungs for goood measure.
Rig should be between 5500 & 6000 pounds. Links are about 40" long.
What should I do?
What should I do?
