Question on running LS1 intake backwards
civicmindedex79
North Mississippi
My new buggy has the intake turned around on it. I knew that the wiring harness wasn't going to reach the throttle body mostly. Which leads me to my question...for those of you that run your intake backwards. Did you have a custom harness made or simply pull the wires back through the loom closer to the computer plugs? Any suggestions or help will be appreciated.
I am running a 2000 Camaro LS1 motor with the red/blue plugs. Harness was cut down 3 years ago.
I just pulled the wires out of the loom closer to the plug. Jims Performance cut down mine.
i just pulled the wires that was needed for the mass air and throttle body out the the harness and extended the the map sensor wires and called it a day. it is easy and cheap to do
