Rear Mount F**kn Radiators 2
aircrawler
WELL?? in the FARM
ok people taking you advice here and checkin it all... Just orderd my restrictor kit it will b in friday aft. also got some advice from the boys at Pirate and a race shop here. You are all right..
without "purging correctly" which means u need to have a prge valve near or around the thermostat housing not puging correctly= "causes hot spots"
using purified water with minimum antifreeze= the better of the thermal transfer capabilities for a coolant combo. and more enviro friendly
cleaning out the system with an acid you can get from a autoparts store makes sure that that dam radiator is clean...
BUT this is where it can get complicated...The volume and speed of which the coolant system operates and gets its ability to create heat transfer IN the radiator is very high. It has been described to me as a fire hose hitting a brick wall. pretty pictue huh?
Which is why i wonder about the restrictor and worry about the pump? ANY MORE THOUGHTS HERE???? Is THere an inline helper pump ???
There are many inline pumps, Most are expensive. Is your rad inlet definately above the very top of the t-stat out? I have a short rubber hose(t-stat out) going to a hard line that goes into my frame, On top of the hard line is a rad drain so i can burp all the air out at the front. The rad inlet is only about 2 inches higher the the outlet at the engine. I have a spal fan with a loose fitting shroud moving air with the thermo switch mounted at the return line about 4 inches from the water pump so the fan will run the least. Having 12 gallons of water mixed with water wetter helps, althought you smell heat instead of coolant when you get a leak. I have a inline water pump that i never use, I dont need it.
The air pocket problem is an easy fix, just get a vaccum filler, mine cost me about $75 off the MAC truck
I might sell the elctro pump this winter when i go thru the rig. Its a dedenbear pump, Universal mount and is just under 300 bucks. Dont polish, I bet you have a clogged radiator.
Iteresting that you say that mr BUNK i went and started from the begining again.. parked that whore on a steep ass hill backward and began filling out of containers and not that f'n hose. after a bit ..started her up and watched the water come from the top and go down.IT WAS HALF FULL. and did not see anything come from the lower slots but it was movin like MAD! SO GRASS HOP YOU MAY BE THE WHORE BUT YOU ARE A GOOD ONE:)!!!LOL
The one and only Bunk i am. And military yota is a neat fellow, mainly when he gets back to his trailer with his axle located by a ratchet strap.:fawkdancesmiley:
hahaha, i remember that! you might have left by the time my poor spotting drove me off the side of the snow covered trailer...:beer:
WELL HOW HAVE YOU BEEN THERE KIDDO? Seen Carolyn? send me some of those pics of that beaterLOL!! [email protected] I'll send you some of the bitch to you...CAN YOU SAY 74" of articulation..DRIVABLE!!!! oh yeah i said it.. wanna flex on me!!LOL!! hear from you soon KID
Carolyn? I dont think ive ever met a coralyn in my life. With that said im older than you...KIDDO
OH SORRY Bunk i must have sent it the wrong way ... that was for military yota guy..but if youneed a Carolyn i know a feller!!...ANd i have been known to be a little lower on the BEERS OF EXPERIENCE myself!!!LOL
lets clear all this up, tom i dont think you know bunk, and ya, ive seen carolyn here and there. and kid, i see how its gonna be....:masturbanana[1]:
and for the record, you and bunk are probably about the same age....
AHHHHH WISE GRASS HOP did ya get the updated pics of the bitch??? check your yahoo e-mail.. Hey i have been doing alot of tear outs on suspensions and hokin people up on simple A sem 4 links doing two in the next 2 weeks let me know when ya wanna get ta flexin !!
when i get around to 4 links they'll be tri lower and par uppers.... but thats a ways off, coilovers and by-passes are too expensive... mines simple and works well as is. i will build a new rig before i do anything more to the ugly f'n pile i have now...
