Sandtrap1986
Anyone know a local place to put my computer back to stock and delete the shitty bulldog crap off of it? Called the dealership but they are closed till Monday. Hopefully someone who doesn't cost an arm and a leg
don't you still have the bully dog tuner? if so it should have the stock tune stored in it. Either way you can use your new tuner and program it with the new tune and it will just store the bully dog program as stock.
That's asking for trouble right there.
My bullydog does have a stock mode on the tuner itself but I don't trust it so I'm reflashing no matter what
I'm not a ferd guy but..... agreed. :awesomework:
Put bullydog on a duraturd and watch the ECM poop its big boy pants.
http://www.gopowerhungry.com/
Do this and be done with it.
Love my PHP tunes. The best thing is when pulling up a grade while towing and EGT's start to get hot I switch to a lower HP setting on the fly and keep on cruising.
I also like having the High Idle for warm up or using my winch to pull timber from the woods.
The TS chips are awesome. PHP also does a great job with the fuel, you dont get a tone of :rb: black smoke, turns to a grey haze right as the turbo lights.
Something like this View attachment 56208
haha nice! Is that the PHP Hydra? or did you go with another company other than PHP.
I did the PHP phoenix on my truck cause i didnt have the need/want for the Hydra at the time. The Hyda is cool though, when i get into bigger Injectors, HPOP and fuel system ill go with the Hydra, i like that you can run multiple companies tunes on it.
One tip of advise, be patient when cleaning the contact strip on your ECU. I thought i had it 3 different times, not till the 4th time of peeling even more of the clear glue off i finally got it to work properly. Some of mine are down to the gold and it still works great.
Edit: I just realized it said Tony Wildman at the bottom of your tune list. I have not tried his tunes but i hear good things about them. too many companies out there, this why id like to get a Hydra eventually.
