Ok, this officially makes NO sense to me... However, it is 100% consistent and repeatable, so I'll describe it and let everyone have a go at a diagnosis:
'77 EB, 302cid with aftermarket stand-alone TBI system, C4, D20 with twin-sticks...
High Range, no issues to speak of.
Low Range FRONT, no issues to speak of.
Low Range FRONT & REAR, no issues to speak of.
Low Range, REAR, dump it into Reverse, no issues to speak of.
Low Range, REAR, dump it into Drive, and the damn thing immediately jumps to 2500+ RPM!!! At this point, it will no longer shift into any other gear or position (the stalk will move, but the trans will not react), and the only way out is to kill the motor... It does this EVERY time, and only in 2-Low as described.
It's almost like it's a mechanical reaction, but the shifter mechanism is nowhere near the throttle linkage (if you are familair with EB's, you know what I mean). And besides, it only does it in 2-Low???
It's almost like a computer reaction, but there is absolutely no "communication link" between the trans/t-case and the engine management system.
