Right spark plug?
Technician
I know this has been covered before but I wanna get it right for my buggy. I got a 22r on pane and was wondering what is the right spark plug for my motor? I heard something about temperature rating?
I use a standard NGK and squeeze the gap to .29 it has worked well for me
altfuel1991 said:
Generally with a propane engine in a light duty engine running the original heat range works. On an engine running under a heavy load or boost it is recommended to go two ranges colder. And do not use platinum tip plugs. Platinum retains heat and at high cylinder temperatures can turn into glow plugs in a propane engine.
. I run stock range ngk myself with no issues.
