justin3535
Member
- Joined
- Aug 20, 2016
- Messages
- 15
Rock Bouncer Buggy $40K
Located In North GA
possible trade for family friendly trail rig
All DOM chassis .120 and .188 mix
7075 links
95% 43 TSL Sticky's
17in Raceline Beadlocks
Anti rock sway bar with aluminum links
Corbeau seats
Sidewinder shifter
Fox coilovers
Fox bumps
Rear mounted radiator
Axles -
14 bolt front and Rear
300m 35 spline RCVs
Retubed for pass drop
SOLID inner kingpin Cs
SOLID kingpin knuckles
WOD spring eliminator kit
WOD drive flanges
1410 u-joints
PSC double ended ram
Engine-
Lq4 6.0 ls
Holley Terminator x ECU
Ported heads
Aluminum intake
BTR rocker are trunion upgrade
BTR push rods
Big lope cam (not sure specs)
ARP head Studs
Aftermarket oil pan
Custom headers
Custom fuel cell
Holley fuel pump
Trans -
FTI stage 3 TH400
reverse manual valve body
Derale trans cooler W/Fan
T-case
Twin stick 205
Located In North GA
7075 links
95% 43 TSL Sticky's
Corbeau seats
Sidewinder shifter
Fox coilovers
Fox bumps
Axles -
300m 35 spline RCVs
WOD drive flanges
1410 u-joints
Engine-
Lq4 6.0 ls
Ported heads
Aluminum intake
BTR push rods
ARP head Studs
Aftermarket oil pan
Custom headers
Custom fuel cell
Holley fuel pump
Trans -
FTI stage 3 TH400
T-case
Twin stick 205
