RockRods DVD: Rigs Section = Specs?
BustedKnucklefilms
293
So I am finishing up the editing in RockRods and want to make a section at the end that tells about each of the main rigs.
I need specs for the following rigs. Also post up if ya dont mind me name Dropping you on the DVD. Timmie Cameron, Bryan Cole, Bobby Tanner, JoJo Tanner, Gary Smith, Mike G, Gus (last name)? Wes Kean.
POST UP IF YOU KNOW THE INFO!
Rigs Specs:
Builder:
Owner/driver:
Hometown:
Motor: size & estimated HP
Axles:
Tranfer case:
I need this info for the following rigs:
Tim Cameron: Green buggy
Bobby Tanner: Screaming Blue
Gary Smith: JEEP
Wes Kean: JSM buggy
JoJo Tanner Buggy
Matlock: Bronco Buggy
Mike G: BTF buggy
Bryan Cole: Highlighter
" name? " Riddler
Gus "last name?" EOR Buggy
Randal Key : Big Buggy on 47s
Am I forgetting anyone?
:tc
Owner/driver: Gus
Rig: EOR Buggy
Builder: Essentially Off-Road
Hometown: ???
Motor: size & estimated HP: ???????
Axles: 60 front, 14 bolt R
Transfer case:
Owner/driver: Bryan Cole
Rig: Highlighter
Builder: Coleworx Rock Racing factory
Hometown:
Motor: size & estimated HP: Ramjet 502
Axles: 60F, 14 bolt R
Transfer case:
Owner/driver: Tim Cameron
Rig: Green Smith Buggy
Builder: Smith Motorsports
Hometown:
Motor: size & estimated HP: Motown Small block 454
Axles: Steering 14bolts F&R
Transfer case:
Owner/driver: Gary Smith
Rig: Jeep
Builder: Crazy Horse Kustoms
Hometown: ??
Transfer case:
Owner/driver: Matlock
Rig: Early Bronco Buggy
Hometown: ??
Axles: 60F 14 bolt R
Transfer case:
Owner/driver: Bobby Tanner
Rig: Screamin Blue
Builder: Coleworx Rock Racing Factory
Hometown:
Axles: 14 bolts F & R
Transfer case:
Owner/driver:Randall Key
Rig:
Builder:
Hometown:
Axles:
Tranfer case:
Here are the specs for the highlighter
Specs. For Coleworx Hightlighter
Owner: Bryan Cole
Hometown: Columbia TN
Vehicle Type: 1997 Jeep TJ
CHASSIS
Frame/Chassis Design Custom Coleworx Design
Frame/Chassis Materials 1 7/8-inch DOM
Overall Wheelbase 115 inches
Overall Length 158 inches
Overall Height 72 inches
Overall Weight 4000 pounds
Belly Pan Clearance 21 inches
Wheel Track Width 90 inches
DRIVETRAIN
Front Suspension/Type/Materials 4-Link with 1.25-inch heims
2-inch 7075 aluminum DOM
Front Sway Bar Currie Anti-Rock
Front Shocks 2.0 Fox w/ remote reservoir coilovers
Front Bump Stops Fox 2.0
Front Axle Housing Dana 60
Front Differential/Locker Detroit
Front Ring and Pinion/Ratio 4.56
Front Differential Cover Coleworx
Front Axle Shafts RCV Performance hardened 300-M
Front U-Joints RCV Bell
Front Drive Flanges Polyperformance Chromoly
Front Brakes Wilwood Dynalite
Front Steering Setup KRC full hydro with Eagle Machine
Hexagonal single-ended ram
Front Drive Shaft High Angle Driveline, 1410 joints
Rear Suspension/Type/Materials 4-link with 1.25-inch heims
Rear Sway Bar Currie Anti-Rock
Rear Shocks 2.0 Fox with remote reservoir coilovers
Rear Bump Stops Fox 2.0
Rear Axle Housing Corporate 14 full floater
Rear Differential/Locker Full spool
Rear Ring and Pinion/Ratio 4.56
Rear Differential Cover Coleworx
Rear Axle Shafts Ouverson Engineering 300-M axle with Custom 300-M drive flange with aluminum cover
Rear Brakes Wilwood Dynalite
Tire Make/Size New, just released 43x14x17 TSL SX STICKY
Wheel Make/Size 17x9 Aluminum Raceline with custom
Coleworx polished rock rings
Wheel Bolt Pattern GM 8-lug
POWERTRAIN
Engine Make GM Ramjet
Engine Displacement 502
Engine Torque 565
Engine HP 510
Engine Induction GM Ramjet fuel injection
Engine Modifications Stock
Batteries Optima
Radiator/Fans Be Cool twin fan setup
Air Intake K&N
Exhaust Custom 3 ½ -inch chrome plated
Transmission Make PTC TH 400 with reverse manual valve body
Nitrous converter with 2200 stall and Durrelle
Super Trans. Cooler
Transmission Shifter TCI custom gated, no cable
Transfer Case Atlas 4.3 with custom HD 300-M output shaft
Fuel Containment Custom fuel cell with in-tank pump
BODY/INTERIOR
Body/Body Panels ’97 Jeep TJ
Body Modifications Cut, chopped, and channeled
Skid Plate/Material 6061 aluminum
Painter Name J.P. Patterson
Hood/Grill Jeep TJ
Floors/Firewalls Custom
Dash/Gauges/Switches Carbon Fiber Autometer
Steering Column/Wheel Grant
Pedal Assembly/Cutting Brakes Wilwood dual pedal assembly
Seats/Harnesses Corbeau GT 40 with Simpson Racing Harnessess
Winch Front Warn 9.0 RC
Specs for tim's old green jimmy smith buggy
2010 Jimmy Smith Buggy only 4 months old.
Bottom frame rails and shock hoops are .188 Wall DOM
Rest is .120 wall DOM
116" WheelBase
Motown 454 Small Block with Mass Flo Fuel Injection 600HP
Custom BeCool Radiator Dual Fans
Powerglide built by PTC, straight cut gears, built with the best money can buy
TCI dirt car shifter
3.8 Atlas/ Cable Shifter, 32 spline outputs
Front and Rear steer 14 Bolts with Solid innerC's, Solid Knuckles, Solid Highsteer arms with custom gussets.
RCV shafts on all 4 corners.
4.56 gears, Detroits
Eagle Machine single ended rams
2 KRC pumps, one for the front one for the rear
Stazworks electric over Hydraulic rear steer valve
High Angle Drive shafts front and rear all 1410
44" TN cut TSLs 80% tread
15x10 MRW Extreme 32 bolt beadlocks With Custom Rock Rings
16" Fox Emulsion Coilovers
2 Fox air bumps on the front
7075 2" al links
1 1/4 heims with 3/4 L9 bolts all way around
Full underbody Engine skid
16" wide Kirkey seats/ Crow Harnesses
Wilwood 4 piston Calipers all the way around
Dual Brake pedals for front and rear
Electric Water Pump
Custom built Alternator real high amp built to rev high
Custom Fuel Cell
High Volume Fuel pump
Graphite Automter Gauges
Waterproof Rocker Switches
Warn 9.0 RC winch
randall Key's old RTC buggy
It has a 523 cubic inch Big Block Ford (around 680 hp, & 700 lbs of torque)
*C6 Ford Trans
*3 speed Stakk Monster Box
*2" Overson Axle Shafts F&R
*Rockwell Steer Locker 6:72 Front
*Rockwell Steer Spool 6:72 Rear
*4 Link 1 1/4 hiem joint King 2.5 Coilover F&R
*PSC Steer Cylinders F&R
*1410 Drive line U-joints
*Cut 17-47-16.5 Super Swamper LTB
*MRW Wheels - Double Beadlock
*Willwood Brakes
*B&M Magnum Shifter
*22 Gallon custom Fuel Cell
*Corbeu seats
*Crow 4 point harnesses
*RC 9000 Warn winch
Located in Wedowee, AL
this is all i could find on screamin blue
383 on mass flo est. 525hp. Turbo 400 and 4.3 atlas. 60 front wit RCV's and 14 bolt rear.
Owner: Bryan Cole
CHASSIS
DRIVETRAIN
POWERTRAIN
Engine Torque 565
Engine HP 510
Batteries Optima
Air Intake K&N
Super Trans. Cooler
BODY/INTERIOR
Hood/Grill Jeep TJ
Dang son, you didn't just type up all that from my CRAWL feature did ya? That's a lotta typin'!
ha pretty much all those rigs have been forsale in the last couple months, go to for sale ad, copy and paste, DONE
Owner: jordan (jojo) tanner
Rig: smith motorsports buggy
Builder: jimmy smith
Hometown: hohenwald, tn
Engine: 351 windsor on propane 400hp
Axles: ford 60 front with rcv's 14 bolt rear
Trans: c6 transmission wit 203-205 doubler transfer
Owner: bobby tanner
Rig: screamin blue
Builder: coleworx rock racing factory
Engine: 388 stroker mass flo efi 550hp
Trans: turbo 400 transmission wit 4.3 atlas
rig; THE RIDDLER
OWNER; CHARLIE FOX
BUILDER; COLEWORX
MOTOR;GM FASTBURN 383
AXLES;60F 14BOLT REAR
4.3 ATLAS
410 GEARS LONGFIELD FT AXLES, DUTCHMAN CHRMO REARS
REST COPY HIGHLIGHTER
