So I think I have the rear brake lines figured out but the front I am scratching my head.
REAR brakeline:
master -hardline-> prop valve -hardline-> line lock -hardline-> flex hose at front rear link -hardline-> flex hose with "T" -hardline-> out to flex line at calipers
Front brakeline:
master -hardline-> line lock -hardline-> flex hose at rear of front link -hardline-> flex hose with "T" -hardline-> out to flex line at calipers
can I run a single line to the axle then T at the front axle and not put in a propvalve? On stockers you split the front at the propvalve which I was under the impression for the front it is just a pass through and is really only used as the splitter?
REAR brakeline:
Front brakeline:
