Saggy Yota Doors?
TrikeKid
Auburn, WA
What's the fix for sagging doors on a 2nd gen Toyota? My drivers door drops 3/4-1" when open, I have to lift them into position then shove them shut to get them closed without simply slamming them.
if you put your body weight on your door when you get in or out it will wear the hinges pretty quick.
The fix is to take them off and toss them in the junk pile. :redneck: But it sounds like one of your hinges is just loose on the body side. Mabye you should start by looking at them while lifting on the door to see where the movement is? An inch of movement is a heck of a lot for a worn out pin.
