Saginaw vs psc
  • Thread starter Thread starter rednecklights
  • Start date Start date
R
rednecklights
Guest
Im currently running a Saginaw pump to feed my steering, it works "ok" I think I need add a larger cooler ... I also have a nib psc tc pump.
what if anything would I gain from swapping to the psc pump?
What kind of Saginaw pump... TC is also a Saginaw.... ?
I'm gonna assume you are running a P pump now.
You could spin the tc pump faster and get better low rpm steering maybe. Or swap to a remote reservoir if you don't have one
If the p works and you are happy with it I wouldn't change it.
From what I understand the advantage of the tc is easier mounting in custom applications and it has bearings so you can overdrive the **** out of it by using small pulleys and it won't explode
Just my 2 cents, but since your goin to upgrade the cooler, go with a plate type with a fan, I was having problems with heat, and put that on there with Amsoil Hydraulic oil and it stays so cool you can stick your finger in it after riding all day!
An off the shelf , "P" style saginaw pump, will be rated for anything from 2.4 to 3.5 (gpm) flow and 1100-1450 psi pressure.
Most PSC pumps are 4 to 4.5 gpm and 1450-1650 psi which is much better suited for full hydro applications
Also, a pump starts wearing imediately, so if it is an old pump then it could be worn out and if someone ever ran ATF in it then chances are it isn't producing all that it should
If you have time and are interested in some good facts call Lance at PSC
Fluids, coolers, etc. will more than likely get brought up too - I have had excellent results out of redline and royal purple , cavitation/aeriation and heat are huge problems with full hyrdo and i have personally seen those two fluids almost solve those issues with no other changes than fluid
This sounds like my problem to a T. Good info. I still haven't changed fluids yet to see if it helps my junk for fawking with my damn front end. One day, maybe I'll get it fully worked out.
Crazy question what does atf do to them? I don't run it just curious.
Atf is known to wear the seals in a pwr steering pump - type F atf actually has a grit like substance to it that would eat a pump up quickly
I am using the P saginaw pump. It was all fine after a few months that I heard a lock to lock noise, don't have any idea where the noise is coming from.
I only run CAT 10w hydraulic oil in both my rigs ZERO issues.
Just my personal experience here, but i felt a night and day difference in ease of steering when i went from a stock pump to a PSC pump. I use synth amsoil with a heatsink style cooler ( which i'm honestly not 100% sure is doing a gotdayum thing) and have no heat issues
