ramrod1
Member
Anybody have a source for a cheap camshaft for a 87 samurai? Not looking for a performance upgrade just stock.
Whatever. Might as well go to NAPA for a raping. If you can order it online you should do so.:awesomework:
Not ever gonna come close to using a turd, reground cam. This is like installing overload springs to compensate for a flat tire. Might as well run retreaded tires too.
Stop by the junk yard if you need to be cheap. Just don't go the cheese ball route.
I've got a stock one, comes with a head for $50....PM if interested:awesomework:
Are you serious?????
Ask around this forum. Those "turds", as you call them, are all over this forum and many others. Our regrounds carry a better warranty than new. We stand behind every cam we do. You will never find this quality with a new camshaft. We can not expect everyone to understand cost savings and prudance.
BTW, please explain why you feel a reground is so bad. If you had a bad experience with one I can understand that. But cam failures are usually the result of improper installation, break-in, poor lubrication or incorrect spring pressures.
" You will never find this quality with a new camshaft. "
:haha:
Oh man, I don't think I've ever smelled a more pungent line of bullshit.
Thanks for the help!:awesomework:
A great deal!
You're on here telling people your reground cams are better than NEW billet cams produced by Lunati, Crower and Comp. While you're peddaling welded globs on used cams from castings ?
It's simply ludacris and then you're attempting to crack on someones intellegence ?:looser:
Qman said:BTW, please explain why you feel a reground is so bad. If you had a bad experience with one I can understand that. But cam failures are usually the result of improper installation, break-in, poor lubrication or incorrect spring pressures.
