SAS Buget Steering
Leatonla24
New Member
I know that there are some post out there that explain sas steering, but my computer is slow and i want to skip the search step, so help me out. I want to know if anyone can post a link or give me a website to better help me understand the steering when dealing with a sas. Can it be done without buying a steering kit or is there a budget way.
Hy-steer kit or you could put old yota J-arm steering in it for cheap everybody throws that **** away!!!:; Go Hy-steer....:awesomework:
Save up for hy steer. Find someone selling it used. Its worth it. Don't afro engineer your steering.:awesomework:
If you have IFS, you already have the correct stlye steering box for hysteer. You would need to mount a push/pull box for a J arm setup.Waste of time.
I found arms new 2nd hand for $100. TG brand. All pro Drag link/tie rod for $75 used a few times. And I used a 2WD pitman arm.
Hysteer is well worth it. You will be reverse engineering **** without it, because of the steering box already in place.
If you can't afford the right steering for what you are doing... then what is the point?
Save your $$ and do it right the first time.
Exactly!!!!!:awesomework::beer: J-arm steering breaks and is bent too easy!!!!!:rolleyes:
