Seafoam
JT Law
Oregon City
Ok, searched and found it mentioned but having seen it mentioned here and there.... What the heck is it and what's it do?
thanks
Cleans deposits from yer intake. And it makes really cool smoke shows.
Cleans intake, injectors, carbon build-up, yadda yadda yadda. And like Bunk said... It puts on a rad smoke show if you feed it straight into the intake or a vacuum line :super:
It made my CJ idle noticeably better immediately after running a can through.
Done it on 3 rigs and never really noticed any difference. Maybe I just didn't have any deposits that were built up to clean out. Dunno.
Actually works very well in diesel rigs. Lubes the injector pump and cleans deposits in the system.
We use it regular on cutomer cars and have a lot of people say it made a major difference.
yes, you can.
Get two cans. Take one and put in the gas tank. Take the other and pull off a vacuum line and with the engine runnning at a fast idle let it suck 1/2 of the can into the intake. drop the idle and let it die.
Let it sit about 15-20 minutes and then start it up and drive it to clear it all out. Will dump A LOT of smoke so better to not do it in a neighborhood.
take the last 1/2 can and put it in the oil. Next oil change will pull out all the major crap and the oil will be much cleaner...
Is it going to help or hurt or be indifferent to a tired 4.0 I6 with 170k+ on it and a leaking rear main?
It can only help.
Plus that motor still has a good 130K before it goes tits up.
My old 88 XJ finally crapped the bed at 350K but it was entirely my fault. I ran it for more than 1000 miles 1 quart of oil shy of the full 6. :mad: :mad: :mad:
