alot of the honda seats fit well . i found a set from an mr2 that bolted in and gave me some extra room. I'm 6'2" and dont' feel as crowded as the stock buckets.
Toyota car bucket seats, aftermarket seats. I like my stock buckets actually. Mr2's work nice, they ride pretty smooth. Try to look for the toyota racing car seats from celicas and mr2's because they fit good, and ride nice.
ok bringing this back to the top. I picked up some 95 Integra seats. What's the easiest way to get em installed? someone make brackets for this? Do I use some of my factory bench along with the seats or do I call that skinny guy at Crash Fab and see if he can make something?
Hey Crash I still don't know if you can send pics in PM's.. so here ya go. If there is any "Better" angle, lemme know and I'll run out and snap a pic. Three mounts are angle'd, the third is flat.
I went ahead and moved the post over here. can you get some different angles of the seat mounts jeff? Looks like the problem you might have is one of the back mounts is verticle and not horizontal....
The seats in the 91 are out of an acura and the mounts look the same. The outer front is in the stock hole and the inner is just drilled w/ bolt and nut. The rear inner is drilled w/ bolt, nut, and 3/4" or so spacer and the outer is just floating. I love the sides off the back they really hold you in place. The only thing I dont like is they are out of a 4 dr so they dont lean forward to get behind the seat. Working on figuring out what to cut out of the mechinism so they will go forward.
Toyzuk, damn that sounds easy, and seems about right too.. Maybe this won't be so bad afterall. Mine do fold all the way forward, but it's a reg cab anyways.
