Single ended ram mount help ?????
Mr. leafspring
KUBOTA BUGGY
Alex City AL
Hello fellow wheelers Im running a Dana 60 GM front diff. Im in the process of high steer, arms already mounted. I would love some ram mounting ideas {single ended ram}PICS would B greatly appreciated . Thanks Bobby... :dunno: :dunno: :-\ :-\ :-\
Above is same as mine cept my chunk is on the other side. Ram position and direction is the same though.
I am comming up to mounting my ram also and have seen that almosr all are mounted to the tierod like in the above pic.
I am assuming that it is so the ram utilizes the pivot from the joints on the tierod?
I had intended to put a pivoting joint on the truss mount and go right to the high steer arm with thw clevis on the ram. is this a good idea?
Thanks,
Sam
This is how my friend did his Assist but there is no reason you could not do the full hydro like this as well.
