nhl_bullitt
Southern IL/MO
Simple concept, but I have concerns.
I'm surprised how often I see a basic bolt holding the skid plate on. Must mean I should not worry about it that bad??? I have removed a skid plate before where it had tapered bolt heads (countersunk) that sat flush with the bottom of the skid. Problem was rocks had gouged the metal of the skid and into the bolt head as well on a couple of the bolts. It ended up having to be drilled out.
I saw someone on here actually used hose clamps. It is not exactly stylish, but you are left with a smooth surface, easy removal, and extremely cheap and easy to replace as well.
