2014 Jimmy's 4x4 vs 2011 SXOR, one will sell
Full spec sheet on SXOR
Chassis ' 4130 Chromoly 1.5" tubing
Engine ' 410 HP LS1 Crate Turnkey
Transmission -TCI TH 350 "Street Avenger" 650 HP rated, dyno tested '€œ Reverse Full Manual valve body
Shifter - B&M Prostick w/ gates shaved
Transfer case - Atlas II 3.0 to 1
Drivelines - Tom Woods 1350 offset joints
Front end: Flipped Dana 60 35 spline 4.88 ratio, spool, Spidertrax 1550 knuckles and RCV 300m axle shafts and joints
Rear end: Flipped Dana 60 35 spline air actuated OX Locker 4.88 gears
Willwood Brake pedal assy with dual cylinders
CNC cutting brakes '€œ stainless brake lines w/ Teflon coating
CNC throttle pedal and cable
PSC full hydro steering system with large filtered reservoir
Derale oil cooler, power steering cooler,and transmission cooler
Griffin 31 x 19 radiator
Interior: VOX intercom - back up camera - dual battery switch '€œ Black out digital gauges ' Waterproof switches and breakers for every circuit ' All accessories are wired with waterproof Delphi plugs -
Dual Odyssey Batteries -
Dual turnkey Peirburg fuel pumps and prefilters
Dual fuel systems complete tank to regulator a 7 gallon and 11 gallon '€œ
Morroso fuel regulator
Thorley headers and morroso mufflers
16' be cool fan '€œ 10' derale fan 10 derale cooler fan
5 light bar with 120 watt Vision X LED center light
Rear view mirror
24 x 19 racing nets
RJS 5 point belts
Driver's seat - PRP Podium memory foam heated
Passenger seat -kirkey
Racerunner 14' triple bypass shocks
Racerunner 14" emulsion coil carriers
7075 aluminum links
Warn 9.0 Rc winch - small spool
Monster Raceline 17' Beadlocks with OMF Domes
New 39" BFG Red label sticky Krawlers
Skid plates - ½ UMHW entire belly, engine and boat sides
SXOR designs BR tech racing hood and panels
All AN or push lock plumbing w/ shot off valves
Dual victor JR air compressors -
Designed with a rear upper deck and rear cargo box for race gear -
Same basic Chassis design as the stainless vehicle in Crawl Magazine
80' wheel track 106' wheelbase 3300 lbs, 1600 front weight and 1680 rear
19.5" belly
72" top
Go-Fast suspension tuned by Wayne "Zukizzy" Israelson
TK1 sway bar
Video on Moab,UT area BFE Upper Helldorado Waterfall
http://youtu.be/JywL1i2zpg0
