ENGINE L33 All aluminum Chevrolet 5.3 Vortec V-8 was told less than 4000/miles
Jims Performance PCM Flash Rev limiter
set at modest 5200 RPM
All aluminum radiator, electric fan with
cutoff switch
TRANSMISSION TH400 Built. Art Carr "Reverse Manual" valve
body with engine braking
Art carr shifter with "Rock Crawler
Reverse" Gate Plate Pattern
TRANSFER CASE DANA 300 4 to 1 Kit; Twin stick; Billet shifters
FRONT AXLE DANA 60 5.38 Full spool; 35 spline Chromoly Inner and
outer shafts; RPM Offroad "Heavy Duty Edition"
Drive Flanges; BTF High Steer Arms;Full Hydro
Double ended ram steering; Disc Brakes
REAR AXLE 14 BOLT 5.38 Full Floating; Government Locker
Disc Brakes; Pinion Guard
WHEELS/TIRES 17" steel wheels with 40 bolt weld on beadlock
Custom Painted
42x14x17 IROC Bias Very good tread (3) tires hold
perfect air; (1) tire has slow leak possibly from
mounting-takes weeks to loose all air**(2)
additional spare tires
SUSPENSION 114" WHEELBASE Flex measured with fork lift w/5.
FRONT 43" REAR 47"
FRONT-- 4 LINK Sway-A-Way Racerunner 2.0 with
Racerunner Coils; New lower links with hemi joints
REAR – 4 LINK Sway-A-Way Racerunner 2.0 with
Currie AntiRock sway bar
SEATS Hunsaker Bucket suspension seats with sliders,
bolted to roll cage
WINCH WARN 8274 Amsteel Blue Synthetic Line
12 Volt Guy in cab control
BODY 1994 WRANGLER, Custom "fastback" roll cage tied to frame w/mesh
over occupant; Custom rock sliders; custom front
and rear bumpers; custom removable cargo rack;
full custom removable skid plate protecting transfer
case and transmission; custom front tube fenders
with diamond plate siding; competition cut rear
quarters; steel half doors and tailgate with working
latches; custom aluminum dash to increase
visibility; led tail lights. There is no windshield and
there is some trail rash.
FUEL CELL RCI 15 gallon Aluminum secured behind seats
CB Cobra with Firestik antenna
Stereo Sony AM/FM/CD player with front aux plug mounted in
waterproof case; 6.5" marine speakers mounted underside of dash
https://www.youtube.com/watch?v=hCgkGsnILOI
This is a great machine. Very reliable/capable. Only ridden around 20 Days since new engine install in 2009. Suspension works great, makes **** easy, point and shoot!!
Cash Price $15,000. will entertain sports car/boat trades NO JUNK!!!
NO TIREKICKERS/LOWBALLERS< Don't waste my time if your not serious!!!AND ABLE!!!
CLEAR TITLE IN HAND.....Currently TAGGED IN AL...no blinkers, windshield, not reccommened on road, is a handful over 35
Located Decatur, AL 35603 text 256.566.4732 (tom)
More pics at
http://s1293.photobucket.com/user/jtbacke/library/
trailer available after jeep is gone for $2800.00 Custom Built 6"channel
5200lb axles-both braking
16" wheels Tool Box
cutoff switch
Custom Painted
FRONT 43" REAR 47"
bolted to roll cage
More pics at
16" wheels Tool Box
