Sold/Expired SOLD Mike George "Evil Bastard" Twin for sale 30k (reduced price) SOLD
zebrajeep
SOLD
$30,000.00 (reduced price) or trade for C6 Corvette plus or minus cash
Located in Mena, AR 71953
Most of you guys have seen Mike's buggy. Rumor has it that this is the second prototype of the famed "Fusion 2" chassis. I actually talked to Dan DuBose to verify this and he did. He built the one and only "Evil Bastard" now owned by Mike George. Here is a video of it when it still had the unimogs.
Mike George in Evil Bastard - YouTube
Note the front upper grill tube where it curves around the headlights. You can't even pay extra to get Blue Torch Fabworks to bend it this way now. They deceided it was too labor intensive and now make the grill this way.
Dan's buddy "Joel" built the other prototype and this is that buggy.
This buggy underwent a complete overhaul two years ago by Jace Baker in Texas. Jace is a very busy man and sometimes gets "bored" before completing a project. He sold it to me "almost finished," and I completed the project. He put a complete new steering system on it, re-did the brakes, put new coilovers and added air bump stops on all four corners. He also completely disassembled it and epoxy painted the chassis and added a new Atlas II 3.8 transfer case.
I did all the elictrical, added a CB radio, on board air, rock lights, back-up lights, and put a rear pull down winch on it. I have the 7075 Branik aluminum links, but haven't installed them. I have put new skins on it this year and upgraded to new 42" BFG red label stickies on 20" TrailReady HD Beadlocks. I also upgraded the fuel cell to the Steel around plastic bladder Summit for safety.
Here are the build specs.
Chassis:
Bluetorch Fabworks 2 seat Fusion (1 3/4" x .120 DOM)
BTF interior sheet metal, Rocker Protection, Bottom Skids,
BTF skin tabs, orbital mount ECT...
BTF link mounts & brackets
BTF Optima Battery Tray
BTF fiberglass Cowl
TJ Hood & grill
.030 aluminum skins
All parts/chassis were shot blasted then hand sanded & redone
2 coats of epoxy primer (for durability), 2 coats of storm gray pearl (house of kolor), 2 coats of DuPont clear & Fresh LINE-X on interior panels.
Motor:
GM Vortec 4.3 (Very clean low mileage motor) (220HP)
Howell EFI harness (nicest harness I’ve seen to date)
Howell ECU
Eldelbrock shorty headers
New intake
Griffin aluminum radiator w/ New RCI recirculating catch can
& 16” Perma-cool Electric fan
Transmission:
GM700R4
New big ass De-rale Electra cool Trans cooler w/ elec fan (Never gets hot)
New Russell AN line and fittings
B&M pro-stick cable shifter with gates filed for "drive to reverse without pulling lever
Advanced adapters Atlas Adapter w/ Energy poly mount
Transfer case:
New Atlas II 3.8
32 spline outputs (front & rear)
Billet shift knobs
& Roark Atlas support ring
Axles:
Fresh Unimog 404’s
3.54 R&P, 2.13 reduction (7.56)
Completely taken down, sand blasted & gone thru with
New seals, gaskets, o-rings, grease zerts, ect..
Built w/ all the goodies
Upgraded box bolts
Exaxt Pinion Conversions
8x6.5 conversions
Disc brake conversions
BTF high steer arms $$
BTF link mounts/trusses/shock tabs
Suspension:
Triangulated 4 Link front & rear
Links are all 2” Solid 7075 T6 aluminum
1.25” x 1” Bore rod ends w/ high misalignment spacers on all
Sway-a-away 16” 2.0 Remote res Coilovers w/ triple rate kits
King 2.0 3” Air bumps @ all 4 corners
Steering:
PSC pump w/ remote can
POS 6” reservoir w/ filter
POS orbital
New 15” Heat sink cooler
New PSC 2.5” double ended ram w/
Large Clevis ends & HD double ended link kit (3/4 Heims)
PSC 4” column
PSC steering wheel w/ splined disconnect
Brakes:
Dual Wilwood 3/4” master cylinders
Wilwood dual pedal assy. (Left pedal rear, Right pedal front)
New Russell braided lines & fittings
New Corvette 4 piston calipers $$$
Chevy 2500 rotors
Tires and Wheels:
New 42” Red label Krawlers
New 20” Trail Ready HD Beadlocks (6” backspace) (less stress on mog box’s)
Misc:
Autometer ultra-lite gauges (Water temp/pressure/volt)
Summit 12 gal. Pro Sport Fuel cell (steel with plastic bladder)
Jegs (Walbro) high pressure electric fuel pump
Russell AN fuel lines and fittings on everything
Moroso Breaker’d Switch/Start panel
Hella rallye 3000 lights
Hid Fog lights
Front Driveshaft by Longview Driveshaft 1350 u-joints
Rear 3/8 wall driveshaft 1350 u-joints
Front Warn M8000 winch with pulldown pully on axle
Rear 3000lb pulldown winch
New Viking 3/8”x90’ Winchline w/ Excel hook & alum. Fairlead
Corbeau Baja SS suspension seats w/ RCI harnesses
Optima yellow top battery
And much more but I can't remember it all. The Vortec 4.3 V6 starts and runs every time and has plenty of power. The 700R4 works flawlessly even at near verticle angles and never overheats. The twin stick atlas and dual pedal Wilwood brakes allow turning on a dime with front or rear "digs."
This buggy has been up every extreme trail in this part of the country without a winch including but not limited to:
Disney:
Viagra
Cialis
Wailing Wall
Waterfall (left, middle and right side)
The Couches
Toyota Hill
Clayton:
Black Sheep
Waterfall
Gasper's Goo
KT's Trail
Green Mamba
Green Mamba Extension
Walk in the Park (bring your wench to pull the winch)
Ate My Lunch
Plucked
Redneck Millionaire
Hot Springs:
Ingrid's
Horsepower Hill
Outlaw
Impossible (one winch)
Too Easy (no winch)
Quicksand
Winch Hill
Warn Hill
Verticle Challenge
Box Canyon
Bonus Hill
Rolling Rock
Here's some videos.
Steep Wall mesko.AVI - YouTube
Rock Pile.MOV - YouTube
Yota hill BigTex Buggy BMR 2010 - YouTube
DSCN0835.MOV - YouTube
DSC_0064.AVI - YouTube
Hate to see it go, but I picked this up last week and don't need two. Located in Mena, AR. Call 479-216-1089
John
Re: Mike George "Evil Bastard" Twin for sale 35k
Few more pictures.
42" BFG Red Label Stickies on 20" TrailReady Beadlocks with Unimogs give it a LOT of clearance!!
This is what this buggy does best. Large boulders with lots of flex. It is unstopable!
Lions Den Harlan KY Feb 2011 - YouTube
More of the same with some front dig action. BIG BOULDERS are what this rig LOVES.
MOV057 - YouTube
Holy ****! Impressive rig and it was nice to see some actually rock crawling....you know slow speeds, spotters, technical ****. thumb.gif
This thing works awesome. I may have missed it....but what is the wheelbase on this
Rock crawling is so boring to watch! But when you drive an obstacle clean, it's really fun. Here's a spot that's really tough near my house. I know it's more fun to watch grass grow, but here it is. Very capable rig.
Rock Crawling Behind the Waterfall Y-City Trail
If you've got a late model Corvette..... Will trade plus or minus cash.
Re: Mike George "Evil Bastard" Twin for sale 30k (reduced price)
Some fresh pics from last week. Had some questions about ride height being too high. I think with the 42s it looks just about right.
Anything that requires a lot of skinny pedal, I usually try slow first. I've really not thrashed this thing very hard at all. Here's a slow attempt at "Horsepower Hill" at Superlift ORV Hot Springs, AR.
Mesco on Horsepower Hill
very impressive vids! extremely capable and clean rig! free bump good luck. just wondering but whats the wheelbase on this machine?
110"
Here's some updated pics from a couple nights ago.
And here's a close up of the small dents in the hood.
SOLD
Going to a good home in SoCal.
zebrajeep said:
SOLD
Just hope you get your money from SoCal. :****:
Are you kidding!!?? Those SoCal boys have the money!! Brought a suitcase full with him to make the trade!!
