muchado
You guys having steering arm issues with H2's? Just wondering because these things have HUGE backspacing..... I was plannin on solid knuckles and hi-steer arms, will I have issues?
P said:H2's ... nah man as long as you dont have some insanely long arms you'll be fine with them . I have put BTF, PSC and other arms on without issues. I do have a set I got from Chad that are very long and they would have needed to be cut back cause the fuggers would hit sidewall but other than that I havent ran into an issue with the H2's. ( 17" aluminum wheel )
Bones said:I'd run regular arms from the start and upgrade as time/$$ some around. I am sure Kelly has arms or can make arms for not a ton of coin??Then again I F'ed up a bunch of **** on my 44 when I lost my steering studs.
Bones said:If you can afford it, then go for it. I do things in stages....several stages
I would go 35 spline first. plus it's cheaper no?MUCHADO said:trufax. I get a deal on stuff from them, we'll just see. I still gotta drop down the fat coin on tires before swappin over so we'll see
Anything else I need to look out for when swappin my **** over? I know I need to address the 30 spline outers--that will happen soon after tires. I take it you guys would do 35 spline and ujoints before you'd do knuckles right?![]()
blacksheep10 said:shafts first. I broke my stock ones right away. still on stock knuckles.
P said:I agree one outters first... first trip out on my 60 I broke the outter doin nothing special and it pissed me off so bad cause I was thinking I spent all this time and money and had me something laughing1
