i recently put corbeuas seats in my single cab yota and its hard to get in and out of i need sum input on and types of quck disconnect steering wheels for it thanks for the input
Dont know if there is a yota specific for your truck or not. Mine is a grant which is splined for a gm collum (36). Got it from summit for 50 bucks, and I am using a lightweight 13" suede wheel for a go cart ($100)
Check summit racing to see if they have one, if not you can get a weld on from them.
Port City, Quickcar and Summit all have generic quick releases. They usually have a hex that welds to the steering shaft. Then an Aluminum collar slides over with the release. You would get a wheel with a blank hub and drill it for the pattern. unless an off the shelf wheel would fit.
