Straps to U-bolts
Jaydog
Edgewood
I have a waggy 44 that has the straps for the u-joints, I want to use the u-bolts instead of the straps, does anyone know if Napa carries these, or anywhere else for that matter, and can they just be drilled out and installed using the same yoke?
Need a new yoke.
If you are a cheapass and nearly broke, you can drill right through where the old strap bolts went and clearance the back side for turning the nuts. Putting on a new yoke is better (and stronger) I haven't seen them in a NAPA catalog so far, but I haven't seen everything yet!
should have them at billy bobs or at least get them quickly. And I would use a new yoke as well.
