Fire Freak
Can you cut chevy stubs down in length to fit a ford hub?
Mine had the length modified, and might have had the diametor turned down also, you can see it in the picture, it is the middle shaft, Top is stock neck downs, middle are cheby 35 spline stub and non-neck down stock, the bottom are 35 spline chromo inner/outersranger11 said:I think you can run the stock Chevy with no mods. mdo817 had them in a ford 60 till he upgraded. You wont be able to put the small clip back on the chevy shaft though.
