militaryota
what year f250s/350s came with which front ends... ive heard so many year range breaks and so on i just want to know....
99 and newer f250s and f350s have Dana 50's in them.
You have to remember...looking at a Dana 50 and a Dana 60 from the outside will show no visual signs of difference.
The Dana 50's look just like a Dana 60 until you pull the diff cover and/or pull the inner axle shafts and find that they are necked down to 30 (or is it 31?) spline at the carrier.
you might wanna check that stat again fella, or do i need to crawl under my 08 and take a picture of the dana 60 for you
Can you put a 60 carrier in a 50 front end?
I sure as hell know my cousin's '99 is a 50
F-250 4x4 and F-350 SRW 4x4 PSDs have the same Dana 60 front axle with 9.75" ring gear.
If anyone can find me proof otherwise, this is what i am sticking with, as it is what i have seen on everything.99-01 F-250's have the dana 50, 2002+ have the dana 60
read my first post, i said the 01 and older SD's that were 250's had dana 50's... so go roll your eyes elsewhere
these are quotes from the superduty site i hang out on
go here, and go to page two, it states the F-250 has a dana 60(for 2004)
https://www.fleet.ford.com/truckbbas/non-html/2004/vs_pdf/fseriessd_04abb.pdf
The list posted above should be mostly correct on what has 60's in it...note on the 2000 and newer rigs whether it is SRW or DRW that they came withso if what im seeing, we dont have any agreement on this subject? same as what i started with...
