T/C new Axles!
MJP
The Bone Collector
Re: Axles! What are these and what are the used in?
Thanks Guys!
Looks like they came out of an All Terrain Lifter, Army System (ATLAS II)
Axle and tires
Make . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Axletech
Type . . . . . . . . . . NoSPIN differential (front) with lube-for-life joints
Model . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .PSOC-205-HOB
Tires . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Goodyear 17.5 x 25, 20-ply
MJP said:
Thanks Guys!
Axle and tires
Where did ya find this info? I'd like to see that website
Somebody find a pic of the airport tugs that the military used. 4 wheel steer, center pivot, cucv cab and drivetrain up to the driveshafts. Look a lot the same. 22:1 final reduction. These might not be that but I thought they looked like it.
I have some of the gen1 tug axles, 4 wheel steer, 55* steering with cv's, 8.5" thirds before the planets with a 1.5ish" shaft prereduction. 20" rims and 4 wheel discs with 2 calipers per wheel on the front. 17.44 final reduction. They look similar to those, but a thicker housing and spring pads.
That's what I thought they were, we had to talk lay out of buying 1 of those things 1 time
I still want to use mine, but it will never happen. I still have Will's single seater and all the parts to put it together, and no time to do so. Can't even finish mine. I had a uroc transaxle buggy bought like 5 years ago, guy flaked on me. It was perfect to put them in.
They are heavy at 1650 # they are for a 10k fork lift with a planitary geared hub.
My buddy has a set of those I think he is asking 2600, but not a 100% sure
4.63 is the carrier gearing and the planataries are 3.6 which equil 16.65 total
The weight is listed by hmtrunner at #1650 and that is correct.
If someone wanted them i would sell them for $3000. They are NEW as in never installed in anything. They have Hydrolic disc brakes alread istalled and are listed as a no-spin axle but I have no way to confirm any of this as Im not going to tear down and New axle to check. They also already have the Hydro rams already setup on the axles.
If anyone is interested feel free to give me a call. They are located in Middle TN 37046
Thanks
Mike
932-797-6676
here is a couple pics of the axles
Here ya go T/C and there just across the road thumb.gif
