t-case/tranny crossmember???
Boonie Buster
Stuck on a Curb
Your Mom's
I have a 350/350/203/205 all chevy setup in my truck now only being supported by the motor mounts:redneck: my question to you guys is, what do i need to look/lookout for when making crossmembers? should i make something to hold up the tranny then a second x-member for the t-cases? or would on "big" one work jsut as good. i want to make it out of square tube, so i can make a flat belly plate for it. would pirate4x4 have any good links on the subject or any other places that have pictures (pictures help me the best in learning:clappy: ) so i was jsut wondering what you guys have encountered in the past from previous experience:cool:
LOOK in here :;
Boonie Buster said:
thanks big guy this should help:kiss:
The setup I did on gibby's is one I desinged on an earlier jeep--owner is a full thorttle type and it hasn't failed yet :;
ok, so after thoroughly looking at them that wont work real well for me:mad: :haha: my 203 is mounted upside down so i lose the use of those two threaded holes on the tranny mount adapter, how did you mount up in between the t-cases? it looks like you drilled into the dual t-case bracket or something. it does help me some though as far as bushings and mounting to the frame a little
who's adapter are you using?
Here are some pics of it....
rear view.
205 shift rails WITH front wheel drive
and my new 203 shifter installed! bad ass! :haha:
rear view.
pIC is blocked for me at work--will take a peek whenever I make it home tonight,lol..
Toyotanut said:
got me an idear or 2....if you are home tommorow afternoon I'll stop by and layem on ya.
cool man, i should be there, give me a call before you stop by, i might be in town colllecting metal, parts, etc.:cool:
