SJR
I got a Toyota Tacoma rear axle with 4.10s would like to install the older pickup 3rd member with 5.29s and a lockright will it fit? or how can I make it fit? would like the wider stance of the Taco
Thats like putting a dana 30 r/p into a dana 44. Just build the taco 3rd as you will get a stronger r/p along with the cross bracing on the taco 3rd has less deflection on the side bearings.
not sure ,Is it from a v6 or 4cly taco?
Some are just the same as the old ones and some are an 8.4 inch (actually an 8) with a cap girdle.
Same spline count on the axleshafts tho.
