Tapping LS water pump outlets
mna0121
Between Geneva AL and Bonifay FL
Remove factory pipes using Vice grips, work them back and forth, they will come right out. No drilling required. The correct NPT tap sizes are 3/8-18 and 1/2-14. Use lubrication, start the taps straight and check your depths against the plugs. Teflon plug threads and your done, takes about 20 min. Hope this helps someone RTR
Yep, I have actually got it in the rig needing plumbing and electrical, then off to JJ's for a set of custom headers. Lots of stuff to change going from the cranking stand to the engine compartment. I have assumed most of the farm duties, have a regular job and a business so not a lot of spare time and just started a twin turbo first gen Chevy II project. My mom took my dad to the ER earlier today while I fed cows. So far just test so I am staying home to feed in the morning. We live close to the river but high and dry for now but staying on call to any neighbors needing a hand moving to higher ground. RTR
