Thanks lucky jeff---zzzzzzzzzing.......
crash2
-Oh no I picked a side-
Da gold bar
Took the dodge into town and NICE :awesomework: I can really hear the zing now.
Upgraded the turbo and cold air intake--and it certainly is alot chipper off the line now
Thank you :cheer:
Cool, I like. There was a noticeable difference in the turbine and exhaust housing, did it :corn: feel like It made a big difference?
Are you 100% positive is better Mike?
Everyone in the other thread said that you'd loose all your low end cause it wouldn't spool up as fast or some shiznit like that...but I don't know what I'm talking about.
Does it have the adjustable boost elbow in it allready?
Not a huge difference in power but a HUGE difference in turbo whine---it totoaly gave me wood :redneck:
I thought it felt beter.....
Adjustable elbo? I honestly don't know what they look like but I assume no...
When you open the hood and are looking at the front of the turbo housing, below the air intake there's an NPT fitting. The stock one is just a connection for the hose going to the waste gate actuator. The adjustable ones come with the aftermarket comp boxes and they have a set screw that you can adjust...just screw it all the way in good and firm. This allows for max boost after you get a box and start adding more fuel.
Guess I'll take a peek at it tommorow...
Glad you got her screamin' like ya wanted :awesomework: . I would have stayed a little longer and BS'd a bit. But I knew I already used up a lot of time you needed in the first place :redneck: . Even if ya don't notice a huge difference now, atleast that's one less thing you have to worry about when you start adding a little more fuel.
