The continuing saga of Wildman's Build
Wildman1
1
Cle Elum, WA
Well after the trail work party I had a leak on the front output seal on the STaK's box. Well I called and STaK's sent me a BRAND NEW BOX. And since I was in there anyhow I thought I would try clocking the t-case a little if I could. Well I could BUT!! The front driveshaft was hitting the rear cooler line. Well as most will remember some where along the way I managed to crack the tranny housing around the rear cooler port.
At the same time before I out about the cracked case I also figured out I had bent the ends of the shifter rods. Not because it was a fault of STaK's but because I hadn't gotten the linkage adjusted right.
Well STaK's sent me shifter rails, gaskets & o-rings for FREE and even picked up the shipping.!! :cheer:
So just to show the beef of the case here is one more picture.
Now since others just like me was having issues with the old shifters. So they had been working on some new designs. Here is what they came up with.
I sent the shifter out and had it powder coated black. Once I had the transmission & shifter back I was ready to start putting things back together.
Because this was a new design I wanted to mock up the shifters before I installed the tranny/t-case in the Jeep. I am glad I did because it sure made things EASIER.
So between taking care of a 4 year old and going to doctor appts I have been trying to find time to work on the Jeep. Well this is a 3 day weekend and the little one has gone to her moms.
I am ready to but the tranny/t-case combo under the Jeep.
Back up under the Jeep & bolted up to the engine. It actually went faster doing this as a combo.
So the new sifter from down below.
And then from in the interior.
So today I hope to get the rest of the tranny/t-case stuff finished off. (driveshafts, skid plate, linkage adjust) Then I'll start on all the other little stuff that needs to be done. I have a rubber mat that I am going to install. I got it from JC Whitney and I am hoping it will cut down on the heat coming thru the floorboard. I have some windshield frame sliders to put on, grill inserts, & hood vents also. Then it is time to start working on the stereo.
So I'll keep everyone posted on how things are going.
Looks good Rick. Glad your Jeep is comming together (again).
Got this intake off Ebay and tried it out yesterday.
Then worked on getting the rubber mat installed. Talk about a PAIN IN THE A$$. Still have more to do to it before it is done.
So I got the skid plate back in place again. The t-case is clocked higher now and I have more clearance between the case and the skid.
But then it is closer now to the body.
So I got a 45 degree fitting for the rear so that I wouldn't have the clearance issues with the front driveshaft anymore.
Well worked on the interior and also finished tightening everything under the Jeep. The bottom side is done for now I think. So here is how the inside is looking.
Well after getting the drivetrain back into the Jeep this weekend I took it easy today. I installed the grill inserts & headlight rings.
Then I put the windshield protectors on.
Was going to work on the Jeep this weekend BUT the ex just told me she isn't going to take the kid. SOOOOO I'll work on it next week when the baby sitter comes over and next weekend I hope.
Glad to see you getting it back together.... Your getting good at that!
I remember reading a write up on the build up, rather then asking questions I would like to read that if you could tell me where it was? lol I get old and forgetfull on where I have read stuff...
Well it doesn't look like I am going to get much of anything done to my Jeep this weekend. The ex flacked out AGAIN and didn't take our daughter. So trying to work on the Jeep with a 4 year old doesn't really work. During the summer I can send her outside but right now it teased us with spring for about 10 days and is now SNOWING again. So hopefully next weekend I'll be working on the Jeep.
I need to put my new front diff cover on.
http://purplecranium.com/wsm/i-115_dana_44_rock_crusher_cover.html
Install my Gen-Right Enduro tank (24.5 gal)
http://www.genright.com/ProductInfo.aspx?productid=GST-2003
Gen-Right hood louver kit
http://www.genright.com/ProductInfo.aspx?productid=LVR-1008
Which I hope will help with some of my underhood heat.
And then install my stereo back into my Tuffy Overhead console that has been modified to fit the PSC Trail Cage.
That should just about finish it for me. Then I HOPE I will have a few weeks to drive it before I have l
