Totalled
That Ford Guy
Don't pay $180 for the Ford racing mini starter kit! It's just a stock starter with a fancy cable!
Starters are $16.99 at pick a part.. of course, all the V8 rigs are missing them already.. but the 3.8Ls are ripe for the picking... as they use the same starter as the 4.9, 5.0, and 5.8, 1990-97. Finally! A use for 3.8L cougars and T-Birds.
Advantages are: Weight savings, smaller size, and greater cranking torque with less draw.
You don't even need to get the solenoid or the cable from another vehicle. simply jump the solenoid on the starter and you can use your original style single lead cable. You may have to drill out the eye that went to the older style starter, so it will fit over the solenoid post.
