Twigs n Berries
- Joined
- Jun 6, 2010
- Messages
- 88
- Reaction score
- 0
Post #47 and # 48 of the trunnion bearing thread
This is apparently a hub of IH8mush, even your wacky professor at the University of Toyota, states that the Birfield can run in gear oil and be just fine
I would like to see the correct information of this subject, if this thread is closed or dealeted than I know we have problems here.
Quote:
Originally Posted by Tranny Frank View Post
for Toyota, Rover,. Dodge, Ford , International, Susuki its all off the same design and they all use a semi fluid grease,
It is all one assembly From the little axle seal to the gasket on the hub...
Then why bother putting a seal between the wheel bearings and the knuckle (hint: it's not "all one assembly")? Why does the factory put wheel bearing grease in the wheel bearings? Why does my factory service manual say to use moly-fortified grease in the wheel bearings and packed into the birfield?
Do what works for you - I'm going to trust the dudes that designed the parts.
___________________________________________
-Eric
Quote:
Originally Posted by Talib Kweli
I'm not a hipster, but I flip it like a sneaker pimp
64FJ40 is offline Report Post Reply With Quote Multi-Quote This Message Quick reply to this message
64FJ40
View Public Profile
Send a private message to 64FJ40
Send email to 64FJ40
Find More Posts by 64FJ40
Add 64FJ40 to Your Contacts
Old 06-24-2010, 07:52 AM #48
longfield
Stuck on funny rocks
longfield's Avatar
Rig: Tube Thingy
User number: 348
X2 thank you.
Longfieldsuperaxles.com
ORDER
-Eric
64FJ40
View Public Profile
longfield
longfield's Avatar
Rig: Tube Thingy
User number: 348
X2 thank you.
ORDER
