tire pressure????
angelfly
Duvall WA
So i'm sure most of u know now i have a fullsize truck that ive been trying to make into a descent trail truck for last 6-8 months. Well i'm finally at the test drive phase and have been working out all the kinks.
I have a set of 36in iroks radial on my 77f250 i have been running the fronts at 5psi and the rears at 2psi.
My ? is can i go lower if so how much and what do u all run in ur iroks offroad no beadlocks either???
42x14x16 Bias Iroks on 16x10s 8 psi, beadlocks not on yet...
3 lost beads in 2 trips out :redneck:
i run 2.5 psi or until they look low, snow wheeling i let the air out until the side wall folds. My trick is silicone, yes redneck beadlocks. Silicone the sh*# out of the rim and tire before you seat the bead and then air up, and last wipe off excess. make sure theyre aired up to full for a few days before you run them low. The key for tire pressure is good judgement, dont run low if your in rocks and tight turns, other wise let it out.
