TJ coil spacers
blackrubi1
Active Member
Lakeland hills
Has anyone had any luck with TJ coil spacers? I want to get 33's under my 03 Rubicon. Also on a very tight budget. It is my daily driver, weekend wheeler. Is it worth it to run these while saving for a real suspension?
We've got'em on our Pubicon, and they work out fine... We were able to stuff 34's under it with no rubbing problems....
Many guys run spacers in the front to level out their Wrangler when a winch is installed. I haven't heard of any complaints using them.
You will most likely want extended shocks with the budget boost. When you do that your springs will unseat at full droop and the spacers could unseat/rotate/cock ect. I would look for spacers that fit tight to the bump stop tower to prevent this movement when the springs fall away.
Wranglers ride and handle very well up to 3" of spring/spacer lift. Its amazing that you can throw that much lift at the stock geometry and have so few problems.
