TJ Rubicon rear axle gear lube
blackrubi1
Active Member
Lakeland hills
Anyone know if you really need friction modifier in the rear axle in a TJ Rubicon? I Know it works as a limited slip with the locker turned off, but it is not a clutch type limited slip. Anyone with Rubicon not run the FM?
Just run lucas gear oil.
It takes care of the problem. No need to run a friction modifier even if it is required.
NEG-A-TIVE.
The rear limited slip (in all TJ Rubicons) is a Thorsen type differential. The friction that locks the diff is created by the side load of the metal worm gears against the housing (metal to metal = no fiber clutch packs).
Use normal hypoid oil 85-90w. No friction modifier used. The Jeep manual says you can also use 85-140 weight synthetic for "towing/heavy service" if you like.
Jeep did offer a limited slip fiber clutch type diff option BUT it was not used in the Rubis. :awesomework:
