TJ Slider Build
Jaydog
Edgewood
After running Elbe I decided it was time for some sliders, so I went in search and found that the ones I liked were in the ballpark of $380 bucks so I decided to build my own.
This is why I decided to put on sliders
I started with some stamped 1/4" steel that I picked up from the Fab Shop in Edgewood, they usually have a large supply of scraps that you can get fairly inexpensive. It was a little rusty, but a wire brush can clean it up fairly easily
I then got some 1 1/2" Sch 80, they were out of sch 40, the Sch 80 is a 1/4" thick, a little overboard, but it is a slider, I went up to Gibbys and we bent it at 26 degrees on both ends, and cut it so it would fit flush, and welded it up.
We then welded the bottom and sides together.
A little paint makes them look a lot better, I may opt to use a roll on such as line-x, but we'll see how the paint holds up
If you notice in one of the photos above I notched out where it would slide into the body mounts, this was the worst part as I had to cut a 1/4" notch in the rubber mounts, I did this with a grinder, smoky and extremely messy, my arms ended up black with melted rubber, boy was that fun cleaning off, I then lifted the body just enough to take the pressure off the mounts and drove the slider into place.
Prior to installation, I pre-drilled holes for the machine bolts and countersunk them so that they would be flush, after mounting them to the body mounts I drilled the tub and bolted the slider up. Notice I only wash the part of the jeep that I have to.
The bars extend out just a little past my fender flares
Thanks again to Gibby for the use of his bender and welder.
Are you going to throw in a center support so it doesnt bow in when you rub something hard?
No, we discussed it, but figured as short as it is I would have to take a pretty hard impact for it to bow, if I had gone with the 1/8" wall I would have put one in.
I still think it will bow a bit. But you are right that it wont bow much being short.
pretty much exactly what we built for my CJ... $0.00 was alot better than the $350.00-$400.00 from PSC or BlueTorch Fab :clappy:
Not only does it look good but it will keep the rocks away... Nice job i like the way it turned out...:beer:
I think you should add something to the bottom corner too. Something round. Take a piece of 1.50 or 1.75 tube, or pipe even, and cut 1/3 of it's diameter out, and weld it along the corner. Way stronger, and you'll have some nice slider support for rocks and whatever.
