Is it possible to fit toy rotors and calipers on the 60s? One of those things I've always wondered but never seen someone do....:eeek:
Got 60's in my toy and am wondering what mastercylinder you are using to operate the 4 wheel disc brakes?
Thanks
Anything is possible and actually would be very doable..... but why would you want to? Less surface for stopping power. in the long run it would be alot of work with weaker brakes. also the toy caliper is a non floating. so if your axleshaft walks or rotor is not true you can get pedal pumpdown (commonly seen on toy rear disc conversions). in the long run you will find the less toyota junk you have the better off you will be. I would never "turdify" a dana 60 with toyota parts.
Ever heard of a full floating axle? :; Toyota brakes are not junk if setup properly, my truck stops better than a stock Tacoma. I absolutely refuse to run those flawed single piston calipers.
If I stop I'm happy.I think Brad is well can't say it
Fine I will let you be right againI don't get it...what can't I say?
Fine I will let you be right againThe other part came out wrong
We've been over this before...of course you're wrong, you're talking about yota's again:flipoff:
I think you'd be impressed by my truck's 100% toyota brakes Brad. :fawkdancesmiley:
Wanna wheel this weekend?
Are you sure your junk can pull a 4500lb boat anchor around all day?:haha: :haha: :haha:
I was running a Corvette M/C on my Willys with these axles/brakes and worked awesome but without the booster, now running the Toy booster and was wondering if there is a Toy M/C that might work, Already bought a Cressida M/C as it bolts right up and stops it pretty well but is still spongy. Has a 15/16" bore, my Vette M/C is a 1" or 1-1/8" bore, can't remember. Any FJ/FZJ M/C's bolt up?
I am running
:awesomework: go nuts.... like I said it can be done. I have tried every combo of toy parts with ****ty results. The true reality is your are having good results with what you have..... now that being said, have you taken all those parts off the same truck and put on the GM brakes and tried them and had ****ty results and went back to your toy parts? I have done changes on the same car. This is why I use the parts that I do. I run parts that are good.... not just parts that represent the "brand" I like.... trust me if the toy parts where worth a **** I would gladly use them but I moved on about 7 years ago when I was doing similar mods to what your finally doing now! :flipoff:
Full floating axle? no... never heard of them...... why do you need that? you have some wood to haul with your wheeler?:;
